Don't do it... Too wide of a fitment for the 202. I think it would be alright for a 210, but for 202 stick with 8.5" widths max up front. Unless of course, you like to drive in a straight line...
Dave
There are 18x9 Carlsson wheels on Ebay for 950 buy it now. There are 4 pairs. Is 18x9 too wide for all the way around?? I know you can put em on the back but the front will be like in the middle of the wheel!! I was talking to Henry47 and he said this is true they are too wide!!
Dave
Dave
So even if i got 18x8 and 18x9 that would be too wide also??? I was going to buy some 18 inch monoblock 2s from a guy that said this setup would fit perfect on a lowered c-class?? Is he wrong??
You can probably fit whatever you want..if you have the $$$.
Autostart Autostarter
Progress Rear Sway Bar
USDM Bodykit
USDM Foglights
1997 AMG C36 (RIP Thank God)
OEM Bosche Clear Corners
OEM AdvanteGarde Grill
Bilstein Sport Shocks
Eibach Springs
Zender rear lip spoiler
W210 mirrors
WELL NO SHIT!!!!
You asked if they would fit. Well.they can if you want to add fender flares and roll the fender and stuff.Originally posted by jnolte
WELL NO SHIT!!!!
There's a post over at another forum where someone put 255's on the front with no rubbing problem...lowered too. I'm not sure how he did it though..i don't think he mentioed it.
USDM Bodykit
USDM Foglights
Eibach Springs
W210 mirrors
Her it is...my bad he's runing 18 X 8.5.
http://forums.mbworld.org/forums/sho...5&pagenumber=3
USDM Bodykit
USDM Foglights
Eibach Springs
W210 mirrors
Well could i run 18x8.8 in the front and 8.9 out back with out rubbing with it lowered like 2.00 inches??
I think so...i'm so confused now too. I've read 3 different boards about offset, rim size, tire size, spacers etc i'm getting a headache.
I think it all comes down to each car and the factors. what combination of spring pads, type of spring, type of shock, is it an amg(rolled fender). It's so nutty when it comes down to it.
USDM Bodykit
USDM Foglights
Eibach Springs
W210 mirrors
18x8 and 18x9 is the perfect setup for w202 for staggered looks without having to do any body modification (off course this assumed the correct offset)
But 18x9 in the front would be imposibble without the wide body fender
if you trying to get the higher offset the inside of the wheel will hit the steering knuckle, however if you go with lower offset the outside of the wheel will hit the fender..
8.5 width rimm would be the max for CLK (W208), W202.. front..
Regardz,
J Irwan
Wait So 8.8 will not fit for the front on a w202 with no modifications??? I would have to get 18x8 and 18x9.
Regardz,
J Irwan
So this is what it comes down too..
18x8 and 18x9 will fitt. 18x8.8 and 18x8.9 will not fit?? So i need to find some 18x8 and 18x9 rims
Rocky
About the fitmen, the most important factor is offset and width..
it doesn't matter if you go with 18 or 19
18x8.5 and 19x8.5 will have the same offset (for the same fitment)
if you go with with 17 you might have more tolerance on the offset number since 17" wheel give you more room under the fender to play with anyway..
Tire size is another different thing, always follow the guide line
8" width 225 for front, and you could go for 245/35/18 for rear setup.
8.5" width 235 (for front, and if you're using it for the rear you could get away with 255)
9" width 255 or 265 (normally wheel this width is for rear setup).
so the thing about tires if you use the tires that is too wide for the rim , the side wall will bulging out and reduce you fender clearance..
now the spacer is a way to manipulate offset
so let say you want to use W220 S class wheel. Their offset is 44
which is to high for w202.
Then you buy 10mm offset with the wheel offset 44 combo the result is offset 34.. (which would fit to W202
Regardz,
J Irwan
I don't understand what you are tyring to say..
there is not such size as 18x8.8 and 18x8.9..???
Also if you make mistake on your post, please edit it, instead of posting a new ones....
Regardz,
J Irwan
hauahahahahhahahahahahahahahahahahahahahahaha
I just LMAO
Past: 1997 W202 C36 AMG
jnolte,
If you read my original post, you will see that I said 8.5" max UP FRONT. I really think rubbing is an issue on a case by case basis. Some people have had rubbing after installing 8.5" wide rims, others have no issues. But to be safe, 18 x 8 up front and 18 x 8.5 or 18 x 9 should work out just fine. Also realize that a 8.5" wide or 9" wide rim can accept different tire sizes. An 8.5 wide rim can accept widths anywhere from 225s up to 255s. Just another issue you will need to consider once you have your rims.
Dave
Kewl..thanks irwan..now..how about the theory that the same size tire are actually different for each tire company?
Like a Toyo will have larger sidewalls then a S03 of the same size like 225-45/17.
USDM Bodykit
USDM Foglights
Eibach Springs
W210 mirrors
rocky
so far the thickest sidewall I've seen is on the Bridgestone S02 then follow by S03 (this due to the design of the outer ring for rim protection ring from curb..)
That way when you accidently hit the curb the curb will meet the sidewall ring protection first instead of your rim..
I am not sure if Toyo has thickeer sidewall.
Last time I check toyo actually has smaller width ...meaning..
18x9 with regular tires I can fit 255/35/18 just perfect, not stretched and not to wide either, but toyo has to use 265/35/18 to get the same effect (I forgot which model)
so based on this, you could fit more rubber with the same rim width..
If you're looking for tires I would also check the sectional width (this is include the measurement with the thick sidewall such as S02 and S03) and another thing is track width..
track width can vary between tires and type pf tires
in generally maximum performance tires will have wider track week than any all season tires (hence greater contach patch area between the track vs road surface, which result in greater traction)
for example there used to be a comparison between various among of tires for the same size..
225/40/18.
S03 and S03 might have wider sectional width that P-Zero Yellow/Rosso/and Nero (due to its marvelous rim protection ring)
however the P-Zero track width is actually wider (the foot print is wider).
Hope this helps.
Regardz,
J Irwan
Sorry J and shutup Susanto. I have it all straight now this is the setup. 18x8fr offset 31 and 18x9 offset 35 back. With 235/40/18 front and 245/40/18 rear. will these fit with a lowered suspention???
Try this as a tire size guide Jnolte
http://www.miata.net/garage/tirecalc.html
225/40/18 front and 245/35/18 look close to perfect. (given stock size is 225/45/17 front and 245/40/17 back)
USDM Bodykit
USDM Foglights
Eibach Springs
W210 mirrors
I would
run 225/40/18 on 18x8 and 255/35/18 on 18x9 (this is the ideal setup)
The stock tires (C36, C43 and CLK55 )sizes are 225/45/17 and 245/40/17 with combo of 17x7.5 and 17x8.5
245/35/18 on 18x9 would looks more streched out compare to 225/40/18 on 18x8
Hence you be better off running 255/35/18 on 18x9, then you would have the same shape of side wall for front on rear (not too streched out or vice versa).
Take a look at the comparison below
(left: the sidewall shape straight when you're running 255/35/18 on 18x9 rim)
(right: the sidewall is streched out because the you're running 245/35/18 on 18x9 rim)
_____ _____
| RIm | | RIm |
|____ | |____ |
|____ | \____/
If I have to prefer I would try to maintain the same sidewall effect on both front and rear, and if I have to choose one streched and one straight I would do the streched looks on the front and the straight look on the rear..
Always put beefier tires on the rear, it will make the car stance more aggressive.
Regardz,
J Irwan
WHAT THE FUCK IS YOUR PROBLEM?Originally posted by jnolte
DO YOUR FUCKING HOMEWORK AND GO TO TIRERACK TO LEARN THE BASIC THINGS
AND YES, PLEASE TAKE A FUCKING PICTURE OF YOU AND YOUR CAR.
BECAUSE... I FUCKING HATE POSERS!
WHOA!!! Too many F words Susanto!!! Thats not cool. i was just kidding around man i wasent seriouse at all. So what the FUCK is your problem???
(your also yelling)
I was yelling because I was tired of you.Originally posted by jnolte
(your also yelling)
so now that I am just chilling.... let me tell you
why don't you get a picture of your C36, and post it.
Thanks,
Ohhh one other things...
this is a classic saying
"No money, no talk"
so I will say to you
"No C36/pictures, no talk"
Thanks for your attention.
