Since you have plastic-panels, I would advise you to make a new hole in the lower panel. I'm quite sure someone will point you to the proper placement and how to remove the panel..
I'm currently in the midst of fitting the facelifted w210 (folding/dimming/blinking) mirrors onto my w202. As my car does not come with folding/dimming, I need to add these in and I’ve gotten the necessary switch and harnesses.
My w202 comes with heated front seats but I won’t be needing them in the near future as I’m taking it away to a warmer climate ( 30 C all year round ) hence I was thinking of removing the switches and putting the folding switch in them.
The problem is that I’ve tried removing the switches only to find out that it comes together with a busbar connecting the two switches leaving me with two holes on the console. I also found out that the ASR and the tilt/motion sensor switches could not work with the removal of the heated switches as some of the contacts are integrated to the busbar assembly.
So my questions are :
1. Is there a blanking plate that could be used to cover the additional hole other than putting another mod in?
2. Any way to overcome the ASR and tilt/motion switch not working? I’ve noticed that two connections at the bottom of each switch is missing due to the removal of the busbar assembly ( assumed that they’re the live and earth connection ).
I know the obvious answer is to place the switch at the OEM placement which is next to the mirror adjuster switch but I’m not confident with my dremel skills especially with prospect of bu****ing the install and the price of a replacement console.
Any help and pointer is greatly appreciated.
rizal
1998 E240 Avantgarde Black
1998 C200 Esprit Black
::: Sven :::
me i did a new hole in the panel where the windows buttons are.
it's really easy just ask someone with a milling machine
Etienne
Thanks for the replies.I was thinking that the panel have some metal layer in it like the wood trim in my w210, hence the reluctance of doing a new hole. If that's the case then I guess its tool time .
I just need to practice on something first before proceeding on the real trim.
rizal
I did it directly on the trim, came out perfect, unfortunately the pics are on my laptop.
There is a metal layer, but for a milling it's like punching a peper.
Etienne
Would you be interested in removing the heated seat pads and wiring and switches and selling them to me??My w202 comes with heated front seats but I won’t be needing them in the near future as I’m taking it away to a warmer climate
can you just buy a new bottom panel where the window buttons are with a premade button spot? if so where
***C43***
Install it in the factory location at the shift console panel.
If you dont want to drill you can just buy it at the dealer. The plastic (cf looking) panels are 1/10th the price of the wood ones.
I am also searching for heated seatsOriginally posted by SLAMMED_C
Seems that the best is to buy complete front seats...
Etienne
what does that other button do next to folding mirrors? and how much for blur wood panel?
***C43***
that button is for rear sunshade..
those be for the power rear sunshade
W203! yeah... 203.. bite meeh
was there another option that can be done back there instead of rear sun shade? and does anyone have a pic of that?
***C43***
I've got quoted like around 300$ canadian for the burl wood panel (mine is cracked)Originally posted by Ashkan's C280
I said f*ck off I'll do something else about it.
Etienne
COVER IT IN REAL CARBON FIBER!!!!I've got quoted like around 300$ canadian for the burl wood panel (mine is cracked)
Yeah that's what I'm planning to do, I already have the fiber and resin and vaccum system for that (we are building carbon fiber wheelchairs prototypes) so I'll use that equipment.Originally posted by SLAMMED_C
I'll probably do it next spring.
Etienne
