Sombody???....where's slammedC!!!
im swapping my belt system for the 230 setup.
Iv installed a 230 engine crank pully and relocated the alternator,but it seems the water pump pully is a different size on the 230K and 230....
could someone help me out with the actual pully diameter for the 230??,and part number(not so important)....
Thanks guys!
Paul
>>99 S202 RED 250TD Daily.
>>89 2.6 RED w/16vkit. POS
i would gladly help u if u would give me direct directions on what to look at and how to measure it (not much of a mechanic but if all else fails) im always here with nuthing to do
Great,if you can,i would like the max diameter of the pully behind your viscous Fan,and the diameter of the little alternator pully located on the left front of your engine...thanks!Originally posted by Abuimad
