Originally posted by stox
Sorry for the sarcasm. Two things will probably happen, you'll burn wiring, connectors and relays, and the voltage will be too low to your ECU, among other things. Your electrical system is not engineered for such high wattage bulbs. Chances are your ECU will clear up once you put the regular bulbs back in. If you're lucky, you haven't burnt the wiring yet. Put the 55W bulbs back in NOW before too much damage is caused.
Thanks for your advices..my bad...I used 110W bulbs....
