Try taking it to another shop to get a quote. If it's leaking from the front, then it could very well be the input shaft seal or a torque converter seal which would require you to remove the transmission. $1000 still seems like a bit much though.
Ok so the tranny is leaking "up front" and somewhere else.
Homies said they need to pull the tranny off to get to the seal and fix it. They want $1k.
They say they dont need to tear it open all the way however.
So my question is...what to do now....if they're gonna pull it down to fix that, should there be some preventive maintenance to be done on the tranny?
And 1k for it..ain't that a bit much?
Car be '99 C280 w/ some 80k miles.
2007 FJ Cuiser
2003 E55 AMG
2012 535i
2005 545i - Retired
1994 C280 - Retired
Input shaft seal for Manual Trans, TC seal for Auto Trans. $1K is way too much. If it has lots of miles I'd consider having it "overhauled", especially if it is the eletronic version.
moebiusgold
\'95 C36
If the gearbox is leaking in the front, it's probably the 2 rubber sealings on the electrical connector, that's the case in most of this gearboxes (722.6).
These sealings is changed pretty easy with the tranny still in the car.
In 98 of 100 this is where it's leaking.
So take it to someone else for a second opinion.
C36 AMG -95
Antera 309 8/9.5-19\"-235/265
Since they're gonna pull it down might as well change your head gasket, valve cover gasket so you don't have to do it in the future. Do it once and do it right.
Thanks for the tips guys. I'll take it to the shop sometimes this week.
2007 FJ Cuiser
2003 E55 AMG
Whoa man... this one's gonna rack up the bill
Don't worry, Doc's gonna find some mexicans to do the job hehehe...did i use that term right?Originally posted by Brabus
Autostart Autostarter
Progress Rear Sway Bar
USDM Bodykit
USDM Foglights
1997 AMG C36 (RIP Thank God)
OEM Bosche Clear Corners
OEM AdvanteGarde Grill
Bilstein Sport Shocks
Eibach Springs
Zender rear lip spoiler
W210 mirrors
werd lolOriginally posted by Rocky
2007 FJ Cuiser
2003 E55 AMG
next time when you get a 'used' car get certified pre-owned so if anything goes wrong you can send it back to the dealerOriginally posted by Dr. ///AMG
Ok, went to the stealer. They want $900 and they will replace all the seals on the tranny. For the job they need to take it down.
Also, if anyone 's interested, I got a local indy shop called german auto, who can do a tranny swap w/ a rebuilt tranny for $2800 installed.
2007 FJ Cuiser
2003 E55 AMG
damn FCUK kimball they suck sheitOriginally posted by Dr. ///AMG
try trans king they do a pretty good job on tranny as far as i know and they DO know euro trannies (basically ZF trannies)
lol you from SLO?Originally posted by Tequila P
2007 FJ Cuiser
2003 E55 AMG
do you happen to know how much a brand new tranny cost?Originally posted by Tequila P
