throttle actuator rewire help... plz
Hey I'm a new member love the forums BTW lots of help... well the problem that i have is my '94 c280 w/o Asr throttle actuator needed to be rewired. so i took it out broke it all out and started the process and thought i labeled everything perfect until i realized that the numbers on the board and the connector are diffrent by the time i realized this it was too late. so long story short i was wondering if anyone knew of a wiring diagram that is hidden on line somewhere Ive found some other models basically every thing expect what i need again i just need form the connect to the solder point on the board.
