Results 1 to 5 of 5
Thread: C43 Cylinder Head Technical Data- Need
    Need C43 Engine Data - Technical
    I am looking for the cylinder head info. I hope someone can help.
    In. Valve: diameter and wt.
    Ex. Valve: diameter and wt.
    In. & Ex. Spring: free length, installed length, diameter, seat & nose pressure, one or two springs
    Rocker arm ratio:
    Cam Shaft: lift, duration on tappet and at 1mm/.050" lift.
    Cam Duration at .200" lift.
    Thanks in advance for the person who takes the time to locate this for me.
    I called and search and came up empty handed. I will check out some of my books tonight to see if there is anything in there.
    Perhaps HPS guy might be able to grab the info for you if you ask nicely
    Speedy,
    I'll see what I can do.
    Can you call me direct so I know exactly what your looking for?
    Originally posted by HPS
    Speedy,
    Rocker arm ratio:
    All there go find it now.
