220 front calipers to 202
220 caliper appears to be the same as a c32 caliper (Brembo casting numbers are the same on both calipers). I've been trying to find a disk that will work on my 202 with the 220 caliper.
At this point I don't care about bleeder/small piston/large piston issue, (the calipers are easy to disassemble fix the bleeder/small/large issue) or wheel clearance.
All I need is a source and stock number for a front disk that will work.
Can anyone help??????
