Page 1 of 8 123 ... LastLast
Results 1 to 25 of 180
Thread: AMG ECU Tuning by SpeedInnovation
    K1 Motorsport presents ECU tuning for W202 AMG engines powered by SpeedInnovation.
    1998-1999 C43 AMG
    93 RON: 27hp, 24lb-ft gains
    91 RON: 21hp, 18lb-ft gains
    1997 C36 AMG
    93 RON: 24hp, 25lb-ft gains
    91 RON: 19hp, 19lb-ft gains
    1995-1996 C36 AMG
    91 RON: 18hp, 19lb-ft gains
    Regular Price: $599.99
    Club202 Price: $549.99. Over $200 less than PowerChip!
    FREE shipping to continental US if applicable.
    * 8.25% sales tax applies to CA resident
    K1 Motorsport
    ECU | HID | KW | K-MAC | AMG | Camber Kit | Argos
    Dec 2006
    Norcal
    2,864
    97' C230 ??
    Do you have numbers based on 91 PON? Also, is there any kind of performance guarantee? Would you happen to have any dynos available?
    Yes! I'd be happy to be the dyno car for your product. Already have a recent baseline.
    27 hp is a huge gain, im skeptikal until i see dyno or a guarantee!
    Sep 2006
    312
    Originally posted by RemoLexi
    97' C230 ??
    99' C230K?? not that I could energize my car over to america
    Standard 1999 C230K Sport
    Mileage: 120K
    Tyres: Pirelli P6000
    Ditto.
    97' C230 ??
    97 C230
    91 RON: 13hp, 16lb-ft gains
    Price: $299.99
    K1 Motorsport
    Yes, revised the initial post with 91/93 PON. We offer 7-day money back guarantee.
    K1 Motorsport
    Dec 2005
    2,213
    Price: $349.99
    is this a plug and play unit? or do we have to send our ECU to you to be reprogrammed?
    You need to send ECU to us to get programmed.
    K1 Motorsport
    Dec 2005
    2,213
    what is the turn around time?
    If you are local from Los Angeles area, it will be done on the same day. If you are shipping the ECU to us, it is normally sent back to you on the next business day.
    K1 Motorsport
    Mar 2006
    1,884
    i speculate these types of gains would need to be tuned on a dyno. are you guys using a generic ECU program from a tuned car to yield "expected results", or do you actually read the stored fuel map, and tuned based per ECU.
    if it's the later route, this is a pretty good deal for custom tuning, because it wouldn't be limited to stock hardware (exhaust, cams, intake etc), however it stil lwouldn't produce the optimum results as being tuned on a dyno.
    Looking at the SpeedInnovations site, looks like cookie cutter ecu tuning.
    I do not think you can get true dyno ecu optimization for ~$500.
    What Kind Of Effects On Gas Mileage Would Be Expected?
    Can You Tune Say, A 98 C280? What Kind Of Gains Would Be Noticeable There?
    1998 c280 (WHITE)
    Kenwood Excelon KDC- X579 Head
    KAC iP500 Ipod Interface
    2 Kenwood KCF-w3012 1500Watt 12\" Subs
    Sony GTR2002 1200 Watt Amp
    More Mods To Come
    This is complete custom tuning. It is most expected and helpful if a customer sends a true dyno along with the ECU. Otherwise, we'll go by what we see inside the ECU because we don't cookie cut.
    K1 Motorsport
    98 C280
    91 RON: 15hp, 13lb-ft gains
    Price: $299.99
    Yes, you will notice the gains.
    K1 Motorsport
    I've read that custom tuning is performed on the dyno, to give real-time data analysis. You can monitor everything: air fuel ratio, load bearing, etc etc. This method gives full spectrum of scenarios and allows the programmer to account for changes.
    I cannot see how you can do custom tuning without the dyno, and as you said for this product it is not necessary. That in itself confuses me.
    Im not knocking the product at all, but want to make sure everyone is fully informed of what is being presented.
    Aug 2003
    212
    I'm always skeptical about simple ECU 'remapping'. The engine can and will only run at the fuel/air ratio dictated by the O2 sensor. Any attempt to vary this by telling the ECU to interpret the signal differently or compensate somehow will result in 1) raw, unburned fuel entering the catalyst and trashing it or 2) lean burn, resulting in trashed pistons. You cannot and should not vary this optimum ratio. Race vehicles with no catalyst are a different matter.
    Normally, all a reworked ECU (no dyno optimization) will consist of is more aggressive timing map throughout the RPM range. This is guaranteed to cause problems in hot weather as AMG is already pushing the timing under a lot of circumstances to the point where the knock sensors must pull it back. Reliance on the knock sensors ALL the time will cause knocking in hotter conditions that can't be gotten rid of (the C36 already does this by the way) as the sensors can only compensate just so much.
    If you run more aggressive timing in very cold ambient temperatures, you might see a slight gain, but to guarantee overall gains under all conditions is not realistic, and to guarantee it with no dyno optimization on a particular vehicle is equally unrealistic.
    \'05 C230k (the wife\'s car)
    \'09 smart (fun as heck)
    sold all my 202s
    We can do the same thing during a road tune. Which is why any included dyno benefits you even more. Might as well go with Powerchip and question how they tune your car also. It's to the consumer's advantage to bring a printout of a dyno and mail it with the ECU. If not, we essentially "touch up what's missing" and tune with whatever we have to work with, including what we actually see coming from your ECU.
    K1 Motorsport
    Apr 2004
    1,232
    how much for 97 c280, its the m104 engine, can you do ron 93 for it?
    ***C43***
    It should be similar to 1998 C280 posted earlier if not the same.
    K1 Motorsport
    Dec 2005
    883
    We all know claims on software are BS, thats just the way the industry works. 10-12 wheel HP is about the max you can get on any AMG engine with software (unless its supercharged of course). AMG already has tuned these cars so well on the software side theres really nothing more to be had with software alone.
    Just the truth, my 2 cents
    I'm sorry I can't answer all of your questions since I do not know the details of ECU programming. That is done by SpeedInnovation, NOT US. I'm just offering a reputable ECU tuning company other than PowerChip. This thread is meant to let members know what's out there at a competitive rate and yet retain same results.
    If you want to get all technical and discourage this thread, please contact ECU tuning company directly and they'll be happy to answer all the questions you may have.
    K1 Motorsport
