Results 1 to 11 of 11
Thread: offset ?
    Feb 2003
    138
    offset ?
    would a 18x9 with a 35offset and 255/35/18 clear? drop is h&r/w #2 pad in rear.
    Jun 2003
    130
    yep should be fine
    i am running 225/35/18 and 265/40/18, i had to do a little mod on the rear arch (took a few mins), but you should be fine with 255\40\18.
    i am running H&R`s with #1 pad on front and #2 on the back
    Alps
    I'm running 225x40x18 front 18x8 and 255x35x18 rear 18x9 with #2 pads all around. No problem and still got enough room in the rear for wider tires.
    Feb 2003
    138
    nice. thanx for the info.
    Do you guys also have a 35mm offset for the front? I am running an 18x8 with 225 31offset front, and 18x9 255 35offset rear.
    edit: lowering is with H&R's, #1 pad front, #2 pad rear.
    I'm running...
    F = 18x8 et35, 225/40
    R = 18x9 et35, 255/35
    lowered with Brabus springs & #4 pads all around
    1999 C43 - Carlsson 18\" 1/6 Diamond... Vogtland Springs ... Koni Ext. Adjustable... Clears...
    Feb 2003
    138
    denla, do you have any problems with rubbing?
    A little bit on large dips. I believe it's due to worn shocks. I got new ones, just not in yet. Other than that, full turning ability!
    Yes!! et35 all around without any rubbing problem.
    Do you have a pic showing off the front? Wanna see how it looks on the car. Hope that made sense.
    I don't know if the pics here would be able to satisfy your curiosity.
    http://bnzsport.com/forums/showthrea...&threadid=8023
