Just a hunch, but, was it on a piece of broken plastic?Originally posted by GuelphC230
found it under my seat when i BOUGHT THE CAR...
part#126 820 11 11
thanx
Jeremy
part#126 820 11 11
thanx
Jeremy
part#126 820 11 11
thanx
Jeremy
umm no it was between the passenger seat and the center console..Originally posted by Renn 208
why what were you thinking?
this is an actuall peice and does not seem broken..looks like something plugs into it
never mind then...it's just that I and one other person have run into random part numbers on broken plastic found under the driver's seat....turned out to be a plastic part of the drivers seat...but it doesn't sound like that's the case here.
Pop open your hood and trace your water nozzels (those things that squirt the water on your windshield to clean it) hoses down. They will lead you to the water reservoir area. You will notice the hoses plug into something. That something is A 126 820 11 11.
So you are right something does plug into them
Probably just replaced on your car and the tech just threw it inside.
Thanx alot man....when I bought the car I never checked the buttons for wipers or fluid..turns out I have no low intermitent wiper..only fast and faster..and fluid..I don't even wanna know what that will cost me to fix..Originally posted by nokia8860
