Results 1 to 24 of 24
Thread: acceleration
    769
    acceleration
    cmon this car cant be so weak
    I have a 1994 c280
    when Im driving behind someone and they slow down to make a right turn for example, I have to slow down as well, I slow down lo like 20 mph
    so now I have so speed up but I step on the peddall all the way and it takes my car like 5 seconds to start speeding up
    Jul 2006
    Philadelphia/South Jersey
    1,547
    do you push the kickdown button?, i had mine replaced cuz it was broken, check it out. cuz my 1994 c280 rapes at passing
    769
    kickdown button???
    wheres that located??
    Apr 2006
    238
    i feel you predrag, same with my 94 c280. best time to hear our engines roar is at a stoplight and u just floor the pedal. but when im passing there is a 5 sec delay.
    Jul 2006
    1,547
    its the black button under the pedal. when you go full throttle, push the pedal down further until you push that button down, you wil feel it shift or "kickdown" and accelerate way faster because of the gearchange. you should be able to push the button down with your hand under the gas pedal to see if it works. otherwise you may need a new one. try it on a high way on ramp. its my favorite pastime!!!
    Apr 2006
    238
    what? theres a button under the accelerator pedal? thanks for the tip ill check it out in the morning.oh and btw im guessing u would need to go to the dealer to pick up a new button.
    Dec 2006
    Norcal
    2,864
    ya these older transmissions have a really long response time, I drive an 07' C230 almost all day long and I love how they respond much more quickly then the W202's.
    white 97' C230 (sold)
    white 94' C280 (sold)
    white 98' C43 (sold)
    Tektite 03' E55 (sold)
    Black 86' Porsche 951 (sold)
    Black 98' C43 (sold)
    Apr 2006
    238
    psssh..show off
    769
    there is a button but when I press it with my hand it pops back out
    Mar 2006
    471
    LOL!
    Jul 2006
    1,547
    thats good it means it works! yeah you can get em at the dealership for around 20bucks. mine actually didn't have anything to push down, so i got a new one.
    I like my response time
    102
    Lightbulb
    Get nitrous.
    769
    well Its stupid that I have to floor it to get some responce
    Apr 2007
    153
    Try Cleaning your MAF sensor. That could help. Atleast its not a bad issue like worn out clutch packs or whatever links to the flywheel in an automatic.
    2007 E350 Sport
    1999 C230 Komp. with exhaust.
    Dec 2005
    2,213
    if you guys would build a cold air intake like I did, you will alleviate this problem ...no one seems to believe me...just remember the crossover pipe is the key piece in all of this to getting more free-flowing air.
    Dec 2006
    Norcal
    2,864
    ive done that ... now another member is using my setup (Sacc230)
    It did improve response but I mean its just an intake so dont expect 50HP but it is still a good way to improve the response. I also set him up with the M104 fuel injecters I got from OmeyHomey and the combination with CAI worked great!
    Nov 2006
    139
    i think you expect way too much out of the c280. its not a race car. i mean whats the 0-60? like 8 seconds? a toyota camry these days is 6.1 seconds. if you want a faster car. get something else. i have a 1997 c280 and i like just curizing around. obviously i dont expect to make fast passes or accelerate fast. our cars are weak in the performance area but mercedes arent exactly known for their performance besides amg.
    Jul 2006
    1,547
    earlier today i made a left turn, and right after i straightened the wheel i hit the gas and momentarely broke traction and took off pretty damn fast!!. my car is definatly fast enough for me. i want to get o 0-60 timer like a g-tech to test my c280 out.
    Apr 2006
    238
    cant u just wrap that pipe in some sort of high temperature wrap of some sort and maybe it'll repel some of the engine heat?
    Feb 2007
    347
    I donno what you guys are carrying on about...if you slow down to 20, the car's only gonna kick down to 2nd gear, unless you use the kick-down switch, where the car will shift back to first gear and you WILL wheelspin!! Try the pulling power/torque in most other cars at 20 in 2nd gear and compare it to the 280...I donno what more you want to expect from a 200hp car???
    That whole "the older gearboxes shift slower than the new ones" is absolute crap!! My gearbox shifts instantaneously!! And after 180 000 miles of hard use!!! It certainly shifts quicker than alot of the newer auto's i know!!!
    If you don\'t do it properly, don\'t waste our time!!
    The C280
    1995 C280
    1987 MK2 GTi 1800 8v
    Dec 2006
    Norcal
    2,864
    crap huh ? yea okay I may be wrong since I have experianced this "delay" in my C230, C280 MAY be differnt but I highly doubt it!
    to make it even , go test drive a stock C280 and an 06' C230 (V6 engine) these two cars are about the same amount of HP, but test drive them and you will see what im talking about. the newer transmissions are and will be more responsive if you dont believe me - too bad its a know fact since they are 6-gear automatic making them a closer ratio! how can you now say your C280 with what 4 or 5 gears (depending on the production year) is going to respond faster?
    Oct 2006
    1,322
    Originally posted by chewiguy
    Get nitrous.
    No forged pistons, No Nitrous.........
    Feb 2007
    347
    I've driven the current C180k, C230 (2.5 V6 coupe), E500, the SLK32, and the current SLK55 recently. the AMG's have a slightly quicker shift, however the new gearboxes are the same, if not slower than my box! I know they have the adaptive system which adapts to your driving style, but the E500, which is usually driven quite fast was only MARGINALLY faster than mine. the C230 was way slower.
    In Fact, i actually riced against my friend's C230k sport coupe and i beat him by a car length and a bit by 120 km/h!
    So no, i don't think our gearboxes are slow and weak
    P.S. Don't take offence, sometimes i get a bit excited when i speak...many people take it the wrong way
    The C280
    1995 C280
    Jul 2006
    1,547
    C280 ALL THE WAY!!! i really want to race this guys 06 c230 sport with the 6sp auto, lives down the street, i think ill beat him, ive got more torque. and im way cooler anyways,lol
    Drexel Business '11
