Is that a 4" system to the rear? was that needed? lol
2JZ looks really good in there!!...now get sneaky and make a custom mercedes valve cover^^
Ah ok sorry should have red the thread properly! have you had it running? looks loud^^
Not running yet, probably about 4+weeks away. Shouldn't be too bad, i'll add an extra muffler in the middle if it is too loud.
can you take a vertical shot of your dump showing the clearance?
I really need to know how do you make it with a 3.5" coz i need one.
thanks!
Looks good! Nice choice on parts
looks great any update and keep pictures coming nice to see the details ]
ooooh nice.
looking good cant wait to see it finished also could you post a video on you tube on it running
c36 ///AMG ,,, c240 v6 sport
what gearbox will you run
Super tidy!...I like it =)
Are you able to resinstall the firewall?...venting it somewhere would shed alot of built up heat if you can.
btw that black spray(rough finish like honda covers) you used on the cam cover and plenum looks great,hope to use that on my next project as well!
what are the calipers off(what merc) and did they fit on no brackets looks nice
wow beautiful job you did on fabbing up the intake to the OEM box for the turbo looks sick man. i wish we had side markers in the fenders here in the US
Thank you.
While i know some people will have a problem with this-Meh....
I'm not one for AMG badges on a normal Merc or M badges on a normal BMW, but the toyota logo looked wrong when the hood was up. So this.
Car will keep normal C200 badges on the outside, or maybe be de-baddged.
Firewall and heatshielding need to go in, and looking at this pic, i need a new washer res...
Completely mad.
Pro job dude!...The merc badge is gold! not so sure about the amg bit but you made it clean so looks that part regardless^^
So much more room for turbo when they dont lean it to create room for the long intake manifold!.
Air con is now gassed and working, most of my electrical stuff has been sorted, like oil pressure light, reverse lights, temp gauge etc.
Sorted out the wiring to the fuel pump, which took a bit of stuffing around due to the ECU having no fuel pump out trigger for the relay. Initially i connected it via a relaty to the oil pressure switch, but when the car had been sitting overnight and all the fuel pressure had bleed off, and it took a few secs of cranking to get oil pressure-it was taking too long to start. So now the relay is also connected to the starter motor-which gives the fuel pump a quick prime when you crank it, and by the time it starts-it has oil pressure=Much better solution and starts like normal.
I had a problem with the power steering pump cavitating, due to the reserviour being a bit blocked, and the pipe from the Res to the pump not being ideal. Had the res cut open, and new stainless return line welded on, and it all seems good so far.
Car has settled down nicely on the new lowered springs, i may still have to drop the rear a further 10mm or so....
I hope to have it RWC, Rego and dyno'd in the next few weeks if all go's to plan.
