Removing Carbon deposits, HOW???
What type of cleaner do i use?? is there some thing it can put in the engine and run for like 30 mins and do a oil change??
How do i go about removing the deposits from the throttle body and with what???
jason
How do you get carbon in the throttle body?? Spray carb cleaner at high RPM would clean the throttle body. Check your hose from the head to the intake... see if you have excessive oil there.
try using brake cleaner with no cfc's.
