Junaidi,
You might see if a C43 MAS and throttle body will fit on your car, or if they are larger. I can measure the inner diameter of the MAS for you.
If you modify your own throttle body, it will be easy to have it bored out larger but getting the throttle plate made up is difficult and then fitting it to the throttle shaft will be hard but doable.
If I were you I would look at getting you cam sprockets slotted or modified so you can adjust the cam timing. Doing this can sometimes gain 5 to 10 percent Hp.
Also Installing an electric water pump is good for a quick 10hp and may reduce the water temp also.
And if you really want to make a big change go for new cams. Don't get the Renntech stuff, it over priced and not very good, IMHO. Get some cams from Comp cams or Webcam. I can help with the details.
