should i even replace the sensor
because
i erased the code, and didn't come back on so far
idle seems fine
could it be just at one moment or that it happened that one time is a sign of future failure of it?
me donno
here's what i got to keep me busy
P0141, is an oxygen sensor code. Specifically, this code is "O2 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)". Bank 1 sensor 2 refers to the O2 sensor behind the catalytic converter on bank one, which will always be on the same side of the engine as number one cylinder.
i want to do it myself, any pointers? should i straight change the O2 sensor or do some tests on that heater circuit?
because
idle seems fine
me donno
I have MAS issues. I need to buy a new one just dont have the cash right now. But if ur car has normal idle and it dosent happen again then its problay fine.
I hope it is your O2 sensor malfunctioning... not your CAT.
Hey Euro: I have to redo the CAT on my car, but while I am at it, I am probably going to put a new O2 sensor in at the same time. I figure it's better to be safe then sorry, that way I know I won't have to replace it for a while. Point is, depending on the price, you might just want to replace the O2 sensor, it's not difficult at all.
Benzo,
that's what i'm going to do, just replace that one 02 sensor
do you know i need a special tool for it? ( i know one side is plug in easy, but donno other) haven't lifted the car to look at the sensor yet
You know, I am not quite sure, if any tool is needed, it will be a wrench. It could be put in with a bolt, I know a lot of cars do that. I haven't looked on mine yet.
I'd replace it asap. Could cause CAT problems in the future and MB cats are not cheap. You'll burn more gas as well.
Autostart Autostarter
Progress Rear Sway Bar
USDM Bodykit
USDM Foglights
1997 AMG C36 (RIP Thank God)
OEM Bosche Clear Corners
OEM AdvanteGarde Grill
Bilstein Sport Shocks
Eibach Springs
Zender rear lip spoiler
W210 mirrors
No, it wont. The O2 sensor he's talking about is the 2nd bank, which is the post CAT sensor.Originally posted by Rocky
It might not be bad, it's sending a bad signal which can mean two things, BAD O2 sensor that's sending out of range Hz, or BAD CAT which causing the O2 sensor out of range readings. If I were you, I would check the O2 sensor before replacing it. It might be your CAT as I said in the previous post.
on the freeze frame shows it was triggered at 4mph lol
so you know it wasn't my fault
update,
ever since i changed the o2 sensor, car is crazy good
better than new
exhaust note is awesome, lot quicker, crispier, and no more check engine lights coming on at all
