Results 1 to 18 of 18
Thread: C230 not starting, timing problem?
    Dec 2006
    Norcal
    2,864
    so tonight my C230 wouldnt start when I was going to go out.
    ive checked it out as far as I could,
    Problem: engine turns over for about 3 second, fires and stalls. sometimes pops flames out the throttle body. will not turn over for more then 3-seconds.
    -cant be related to the starter, since it ALWAYS consistantly turns over, but only for 2-3seconds and stops nomatter if it fires or not.
    -not fuel related - ive sprayed starting fluid down the throttle body and no help.
    -not the MAF, disconnecting it didnt change anything and MAF is also related to fuel.
    -cant be the crank or camshaft position sensors since engine would keep turning over and over.
    something is keeping the engine from staying on for more then 2-3seconds. is there any kind of theft immobilizer's on a 97' C230 ?
    I feel like this has something to do with the timing or maybe that magnet on the drivers-side camshaft.
    anybody out there that have shared these symptoms or may direct me towards whats causing the issue? tomarrow ill be using my Mac MENTOR and see if I can pull any codes. also have a word with the Benz techs and see if they have seen this before.
    77,000 miles for the info. and lucky the W204 is here as my daily driver.
    any help is very much appreciated!
    white 97' C230 (sold)
    white 94' C280 (sold)
    white 98' C43 (sold)
    Tektite 03' E55 (sold)
    Black 86' Porsche 951 (sold)
    Black 98' C43 (sold)
    Mar 2006
    471
    If everything is connected properly, how can this be?
    If everything is NOT connected properly, then who knows what is normal?
    Dec 2006
    Norcal
    2,864
    I didnt disconnect anything ..
    Jan 2005
    164
    I had this issue in my Corvette after I had removed and reinstalled the ignition module. In this case engine timing as the exact opposite as it should have been (the part could have gone in two ways and I chose the wrong way...whoops).
    Under no circumstances should flame pass up the intake valves when they are open.
    2000 C230K
    1998 Prelude Type SH
    1957 300 SL Gullwing
    1953 Porshce Spyder
    1963 Ferrari GT California
    1988 Dodge Reliant \"K\"
    Oct 2006
    1,322
    LMFAO..........THATS SCARYYYYYYYYY
    Dec 2006
    Norcal
    2,864
    tow-truck is taking her away within the next hour.
    Dec 2006
    Norcal
    2,864
    ... okay, so ive had two differnt tow trucks come by my house, and none of them could load the car because of it being too low.
    but, the good thing is ive found the problem and fixed it so all good now!
    Mar 2006
    1,884
    lol@being too low.
    what was the issue?
    Dec 2006
    Norcal
    2,864
    fuse #25 popped up
    Senior Member Logic's Avatar
    May 2007
    Colorado
    1,428
    you just saved you a grip of money taking it to your stealership
    98 C43 AMG (SOLD)
    Aug 2003
    577
    What is fuse #25. I've seen many tow trucks not want to deal with lowered cars or if they have rims/ kits. Were they flat beds?
    1999 C230 Kompressor Sport, 197
    The modding has started. Too many to list. Stay Tuned.
    Mar 2006
    471
    For what it is worth, Fuse #25 in my C36 is for optional seat heater.
    Perhaps he meant a white-coloured Fuse that was inscribed 25? That would be a 25 Amp rated Fuse.
    It would be interesting to get to the bottom of this mystery.
    Dec 2006
    Norcal
    2,864
    on my car fuse #25 is a 15amp blue fuse. it is realated to the cars locking system and a few other functions.
    I wouldnt even pay a dime if i took it to my stealership, since I work there I have my own personal tech who always hooks it up with any problems I have. I try my best effort to resolve any problem myself - and what I cant do, he teaches me!
    now, one of the first tow-trucks was a carriage ... go figure I cant even stick my pinky between my rear tire and fender so no way could he strap the car and have my front diffuser draging down the road ?? ... the second was a flat-bed. the flatbed tried to pull it up - but the nose of the car would hit the ground and that was it.
    at least i know my car cant get towed.
    Mar 2006
    471
    Hi Lexi,
    I'm with you now! That Fuse you described is #27 on my car. As you say, it is involved with the infra red locking system (and in turn the engine immobiliser system?).
    It stands to reason that a problem with that fuse would give rise to the problem symptoms you outlined.
    Note on my picture below Fuse #25 is not fitted (missing) as I don't have the heated seat option (well I do live in sub-tropical Queensland!).
    Oct 2006
    1,322
    i know AAA would refuse to touch my car because it was lowered, and had rims. I called AAA pissed. I told them my car was not lowerd but it does have a body kit (lied). I pay for a auto service that doesn't service to my needs, and my AAA rep didn't say one thing about my car, and told me i have 4 tows to anywhere i want. I've requested for a flat bed, and you guys send a wrecker. They told me they apologize for everything and sent a flat bed lol.
    Dec 2006
    Norcal
    2,864
    Hi Lexi,
    differnt models, differnt fuse boxes.
    Dec 2006
    Norcal
    2,864
    yea the carriage guy says "C230 AMG"?? im like "yea yea thats right". so that they would think its a sports sedan and not modified and tow the fucking thing. still no go. lol
    great, now I know I have a C230 AMG and you guys are jelous!
    Oct 2006
    1,322
    hahahahahaha...........even with a flat bed mines scrappppp just hauling it up.......c230 amg lmfao wat a fool
