had the same problem. on the passenger side of the trunk in the there is a place where all the vacuum tubes meet. in my c36a tube was off
The central locking on my C180 hasnt worked for a while. Ive tried to find the problem but I cant seem to fix it. When I lock/unlock the car the rest of the locks move slightly but dont lock or unlock. Im guessing that means its a problem with the pump. Has anyone had a similar problem and know a likely fix?
C36
87 190E 2.3-16 Cosworth- EFI conversion, Mosselman turbo headers, Garret, LC1, Megasquirt, 95A susp. bushings, evo2 rear sway, 300te front sway, brass shifter bushings, Sportline wheel, Euros, C36 calipers, Monos, Billy sports, Jamex/H&Rs
86 190E 2.3-16 Cosworth- Eaton SC, Mosselman piggyback, BBS Mahles, Euros, H&Rs, Koni adjustables, sportline wheel, 300te front sway, 300te end links
