Results 1 to 4 of 4
Thread: Timing Chain replacement
    Hello All,
    Any of you guys or girls replaced your timing chains yet? I can't seem to find the interval for replacement of these things in my user manual. I remember when I used to drive my old Honda, I replaced the timing belt at least every 60K miles. My car currently has 75K miles and I'm worried that a broken timing chain can cause me a lot of grief.
    Thanks for any feedback.
    As I remember chains are not needed to be replaced like timing belts.
    1,501
    Lightbulb
    Joey is correct
    Timing chain doesn't need to be changed like timing belt.
    BMW E36 3 series also uses timing chains as well and they don't get changed las often as timing belt.
    Regardz,
    J Irwan
    CKlasse
    Guest
    C36Ryder,
    Timing chain doesn't need to be replaced.. it does need to be adjusted ohhh..at around 200000 miles
