Yep its ok to just run wheel spacers in the rear.. I'm running 15mm H&R hubcentric wheel spacer in the rear.Is it ok to put wheel spacers just in the rear, or should i do them in the front too, and how many milimiters should i do?
how many mm's??... thats up to u.. depends on what u want to achieve.. I'm running 19x8.5's all around and wasnt happy with the way the back wheels werent nice and close to the fender.. so I did some research and found I could do 15mm spacers on each side in the rear to change the offset and make it look like I'm running wider wheels in the back. looks so much nicer now.
