transmission fluid coming from the trans filter housing
Where this leak is coming from / what it is. And what should i try. Would be easier if i had a lift.
Thanks for the quick reply. Fix = ?Originally posted by jnolte
from the looks of it, your leaking from the pan gasket.
i would also look at your transmission electrical plug. its located on the passenger side of your transmission toward the front. there should be a heat sheild over it. its an easy removal with a torx bit. and while your there in that area, check out your dipstick tube seal.
if all of that is good, id just recomend doing a trans service where you will replace the trans filter and the pan gasket.
2000 c230k sport.
H&R sport\'s
Bilstein sport\'s
6k pilot hid
18\" monoblocks with polished lips
16\" O.Z. vega 2peice polished lips, white
centers (4sale)
16\" 202 sport wheels painted black.
(4sale)
It's hard to say. That fluid could be coming from anywhere. Try to see if you can track down the highest point you can see fluid. Hopefully it's just a Trans-pan seal (appears to be from the last picture) which is a relatively easy fix.
EDIT: What year/model are you rollin?
2012 535i
2005 545i - Retired
1994 C280 - Retired
i say it looks like the oil from the transmission leaks !
white 97' C230 (sold)
white 94' C280 (sold)
white 98' C43 (sold)
Tektite 03' E55 (sold)
Black 86' Porsche 951 (sold)
Black 98' C43 (sold)
It looks like the fluid is running down and back from that right front location, so I agree with checking the 13-pin plug connector, and it is a common fault. It is not actually the plug that leaks, but an inexpensive part called a number of names. This diagram shows it as #115 and part # 1402700250:Originally posted by V1Dreamer
... i would also look at your transmission electrical plug. its located on the passenger side of your transmission toward the front. there should be a heat sheild over it. its an easy removal with a torx bit. ...
http://www.detali.ru/cat/oem_mb2.asp...SGR=095&SGN=09
When I replaced mine recently, M-B called it a Spacer with a part number of 2035400253. The WIS calls it a Pilot bushing and Guide bushing.
At http://AutohausAZ.com/ both numbers return their Part Number J2050-277685 AT Plug Adapter.
You'll need a 7mm socket for the bolt in the center of the Spacer.
Here's an external link with your exact symptoms and instructions on replacing the spacer:
http://www.benzworld.org/forums/r170...luid-leak.html
Your leaking fluid looks fairly fresh, but if you still want to drop the pan, here are a couple related links:
http://www.mercedesshop.com/Wikka/Trans7226Fluid
While the next one was on an E series, it's a great DIY pictorial:
http://www.benzworld.org/forums/w210...id-change.html
I also installed a pan magnet 2202710098 when I did my C43.
And the 1402700098 Filter Kit that I purchased from AutohausAZ had the locking tabs to help hold it up in place, unlike some others documented.
1999 C43 AMG Black - sold
- Eagle Eyes: BZ055 Clear Corners with LED 2357A, BZ062 Tails with LEDs; LED lic. lamps
- VVME H7 4300K HID/Xenon Lower Driving & Low Beams (& replaced Halogen Lenses with OEM Xenon Lenses)
- Sylvania SilverStar H1 High Beams
- Silver Star Re-man and improved Trans./Conv.
- Eibach Pro-Kit & Akebono ProACT Ceramic Pads in Front
1999 C280 Sport Black - sold
2005 E55 AMG Black for fun
2007 GL450 Carneol Red for hauling!
Thanks for all the info.
I'm in a 2000 c230K.
Its hard to really see whats going on down there as my car is lowered. So tracking anything is nearly impossible until i buy some ramps. Ill look more into it when the ground drys here. (I'm not driving it.)
awman.......looks like me all over again, how much fluid did you put? Did you also use the correct dipstick? This might just be residual, clean it up....check the fluid.....drive it and check it again to see where its coming from......IF YOU USED AM GASKET.....REPLACE IT WITH A OEM ONE.......
when i did the flush on mines, i looked at alldata.....i think is said 7-8 quarts of trans fulid, but it didn't say anything about draining the torque converter, so i had about 9 - 10 quarts of trans fuild in there altogether. I blew the tail shaft seal
