Steering wheel noise
My steering wheel has been making an abnormal noise every time its turned. The noise is the same sound as when you run out of power steering fluid. Only it's not hard at all to turn the wheel like when you run out of PS fluid. I checked the PS resevoir and everything is fine (full tank of fluid) and I do not have any evidence of leaks on my garage floor. Could this be the PS pump? How can I tell if the pump is bad? Could there be something else that's wrong? Any help would be appreciated.
Dave
i have a problem too, it makes squeaky noises when i turn but i noticed that when the car sits in the garadge then its all noisy..but after couple of minutes of driving it stopes...what happens is all the oil sits on the bottom, and does not lublricate it, but when you drive the car, the oil starts lubricating the whole steering wheel, and it stops
Elvir
