compliments of J Irwin
For W202 mid 96-99
Front(W210 part number) :
210 321 01 84 pad#1 5 mm
210 321 02 84 pad#2 9 mm
210 321 03 84 pad#3 13 mm
210 321 04 84 pad#4 17 mm
210 321 05 84 pad#5 21 mm
Rear(W210 part number) :
210 325 01 84 pad#1 5 mm
210 325 02 84 pad#2 9 mm
210 325 03 84 pad#3 13 mm
210 325 04 84 pad#4 17 mm
For W202 94-mid 96
Front(W201 part number) :
201 321 09 84 pad#1 8 mm
201 321 10 84 pad#2 13 mm
201 321 11 84 pad#3 18 mm
210 321 12 84 pad#4 23 mm
Rear(W201 part number) :
201 325 09 44 pad#1 8 mm
201 325 10 44 pad#2 13 mm
201 325 11 44 pad#3 18 mm
The different between W201 and W210 part number is because of the different shape of the spring.
The W201 spring pad has flat surface where W210 spring pad as a grove where the spring will sit.
On the earlier W202 cars the edges of the spring is tappered, that's why they use W201's spring pad which has flat surface..
Hope this helps.
Regards,
J Irwan
