Results 1 to 10 of 10
Thread: Part number for MAF sensor on C23K!
    Aug 2005
    155
    VIN number is
    WDB2020241F377508.
    Thank you very much for your answer.
    Jan 2006
    1,058
    Pull your MAF off of your car and read the part number stamped on it. In the US, an M111.975 should have either “280 217 114” or “000 094 09 48” stamped on the side. Not sure if it will be the same for Croatia since emission laws are different.
    1999 C230 Kompressor
    Jan 2006
    1,058
    BTW, keep your old housing in case you want to do this:
    http://www.club202.com/forums/showth...&highlight=MAF
    Aug 2005
    155
    Tnx guys!
    Aug 2005
    155
    000 094 00 48
    0 280 217 100
    Those are the part numbers stamped on mine, with circle connector on it. Local Merc dealer gave me that (above) number too.
    Everywhere on Ebay are numbers you have mentioned, at least for C230 Kompressor engine, with 09 instead of 00 in part number.
    Jan 2006
    1,058
    If you have a round connector, then you do have a different type and should not use the numbers I gave you.
    Aug 2005
    155
    Yep!
    Please, look at my engine bay and at the MAF sensor (something is a little bit oily at the bottom of it). Where do you think I should relocate my MAF sensor?
    Jan 2006
    1,058
    The system is very different once things get near the TB, so I am not sure if there will be any benefit.
    Aug 2005
    155
    Hehe, I thought so too.
    Tnx again.
    Aug 2005
    155
    Trouble solved.
    MAF was pretty oily inside, I cleaned it detaily with ABRA CARB & CHOKE cleaner, diagnostic tool showed 0 errors after reset (15 mins battery off) and few miles test drive after that (before that error was number 37 lambda regulation, accorded to BOSCH KTS 550 diagnostic device).
    I am happy now!
