Results 1 to 15 of 15
Thread: Car is in Shop
    606
    Car is in Shop
    Today I was driving along and I heard a pop come from the front of my car - so I thought I might have hit something but I did not see anything in the rear view mirror. I was a block from Safeway where I was going shopping so I pulled in and shut off my engine. When I came back out and turned on the car, there was a very loud ticking noise coming from the front of the car. I decided to take it right over to the dealer with 30 mins left in their work week.
    As I pulled in I could smell some burning and it was still ticking. The service advisor comes out and tells me to turn on the car to show him the problem, immediately he tells me to shut if off. Turns out the some rubber sleave or something like that near where all of the pulleys are up front, somehow burned off and is no longer in place. As a result I think it created separation from the crankshaft - it is around 1 cm. Anyways, it was not good news and a tech came over and looked at it, and was like, oh man that sucks. He pointed to a new S-Class that was in for the same problem. At this point it could be somewhat bad, or really really bad depending on if it shredded anything inside the engine. Needless to say I am pissed, and Starmark sure better cover this or else it will be at least 3g's he suspected!
    S class too? What is this a known problem?
    I also hope starmark covers this for you.
    606
    I guess it has happened more than once, and the tech knew exactly what it was so, anyways, better be fucking covered or I am SOL - yeah no job.
    Apr 2003
    435
    It's your harmonic balancer ( they blow out by the hundreds ).
    It will most certainly be covered by your warranty !
    2000 C 230 K
    606
    Yup, that is what they said, now the question is, if there was additional damage, is all of that covered? I would assume so, but just a pain since I do not have a car for the whole weekend and then some.
    Apr 2003
    435
    I don't think there would be any other damage, and if there is, it should also be covered by the warranty.
    P.S. You may want to check over at www.mercedesshop.com ( technical forum ), and read all the gruesome details on balancer failures.
    2000 C 230 K
    256
    it should be covered, but, starmark is kind of tricky sometimes. for example, they'll prob cover the main part but not the bolt that holds it in place. stupid. they prob won't even look at it until monday afternoon. they'll order the parts on tuesday morning. receive the parts on thursday ~noon. and will finally start work on it by friday...so, yea..here's looking to next friday/following monday at the earliest. i assume all of the loaners are out as usual?
    606
    Thanks, I just read and posted on this thread
    http://www.mercedesshop.com/shopforu...174#post477174
    606
    Probably, but I have had pretty good luck with the people at the Clay street location. They are pretty cool there and give me a fairly confident feeling.
    606
    Just got it back and they covered the replacement with Starmark. They also had to replace the Oil pan since it was damaged as well. Good times!!
    2,283
    Dan, glad your car is back with you and you didn't pay for any of it!
    606
    Got a free oil change out of it too, and it was time for me to do one so BONUS!!!
    2,283
    There you go! Make the system work for YOU!
    713
    stupid question but whats a harmonic balancer?
    Autostart Autostarter
    Progress Rear Sway Bar
    USDM Bodykit
    USDM Foglights
    1997 AMG C36 (RIP Thank God)
    OEM Bosche Clear Corners
    OEM AdvanteGarde Grill
    Bilstein Sport Shocks
    Eibach Springs
    Zender rear lip spoiler
    W210 mirrors
    2,283
    This one's for Rocky
    http://www.autoswalk.com/howengineswork.html
