Dont really have any photos of the install procedure. the comand retrofit is pretty involved.. need to modify 2 single din radio supports to make a double din support, need to modify 2 wood trim pieces to make the trim to fit around the comand, a slight bit of wiring modifications!
the cluster and multifunction steering wheel were pretty simple.. but it does require replacing the srs ring and adding in a small harness for the CAN system.
