Results 1 to 5 of 5
Thread: nitrogen in tires?
    Nov 2006
    220
    nitrogen in tires?
    See some places selling nitrogen to fill ties. Supposed to
    get better mileage, longer tread life, etc. Anyone have this in
    their tires? Is it just snake oil?
    Oct 2006
    1,322
    i think its bullllllllllllllllllllllllllllllllllllllllllshit!! !!!!!!!!!!!
    The whole purpose of it is for dipshits that don't check there tire pessure often....
    incorrect tire pressure can cause vibrations, lower mpg, uneven tirewear, even blowouts...and if you have low pros..lmfao you can't even tell if you have flat tire in some cases
    Everyone should check there damm psi or get a TPS!!!!
    tireblow out at 75 isn't fun btw lmfao
    Sep 2003
    619
    personally i think its bs too, normal air is around 80% nitrogen as it is...so i can't imagine there is much of a difference.
    another selling fact is they say nitrogen doesn't change with temp meaning your tires with just air alone will change +4 when warm whereas nitrogen filled tires will not. also the molecules are thicker therefore air cannot seep out which is why you don't need to check your PSI as often.
    i used to install this on so many cars at the dealership because it's a great selling point. $50 and you never check your tires, but it is indeed a load of crap i think even if racecars use it. i personally wouldn't pay $50 for air - IT'S FREE!!!!
    Jason
    Sep 2004
    525
    The ONLY thing pure nitrogen might do is minimize oxidation on the inside of the tire. The only reason the racers use it is because it has no moisture content. At the temps their tires run, any moisture can result in a substantial pressure difference as the tires may exceed the boiling point of water.
