Results 1 to 15 of 15
Thread: Tranny or sensor issue?
    Jun 2003
    13
    Yesterday while attemting to pass, my car kicked down to overdrive and it stop reacting. No matter how I press the gas pedal it would not react to it and it would not pass 3k rpm. The check engine light came on and I'm yet to get the code today.
    Today if I drive normal car acts normal but if I put a little bit more gas on the peddal the car will not shift no matter what gear I'm on. The rpm will just go up but it will not shift.
    1,037
    MAS sensor........and what model u have?
    99 C43 AMG
    99 C230 Kompressor
    Jun 2003
    13
    I have a 99 c230k with 155k milage. The MAS has been replaced around 60K and It did not have this symtoms, just Check engine light.
    sounds like limp mode
    I thought LIMP mode didnt let you out of 2nd? Banjo, can you shift through the gears as long as you keep the rpms down?
    Jun 2003
    13
    Yes the car shifts normal just as long the rpm does not go up. 02 sensor or the MAF could be causing the issue according to the codes that we pulled.
    Jan 2006
    1,058
    And those codes would be...?
    1999 C230 Kompressor
    Moderator hvmercy's Avatar
    Dec 2003
    2,092
    I agree. All the responses above will just be guesses until you provide the code.
    Jun 2003
    13
    Here is the code P0170 (fuel trim bank one).
    Jan 2006
    1,058
    You are right, that often points to the MAF sensor and where I would start investigating first. When the MAF goes bad, it can cause other phantom codes to pop up too.
    Have you tired cleaning the MAF with MAF cleaning fluid? That is often only a temporary solution but if you can get the error to at least temporarily disappear, it would give you more confidence in investing in a new MAF.
    If your MAF is covered in oil, you need to solve that problem first. Check the whole crankcase ventilation system for bad checkvalves, clogs, split hoses, etc.
    Dec 2005
    2,213
    Make sure to buy the MAF from autohausaz! Cheapest place I know of...
    Oct 2006
    1,322
    the cheapest place i've found a MAF is buymbparts.com
    P0170 MEANS BUY A NEW OEM
    Believeeeeeeee me i knowwwwwwwwwwwwwwww
    you buy that ebay shitttttttt you'll get burnedddddddddddd
    Jun 2003
    13
    Thanks to everyone.
    Oct 2006
    1,322
    Originally posted by banjo
    Thanks to everyone.
    Yeah you can try to clean it with crc maf cleaner. But sometime it gets to "point of no return"
    Oct 2006
    1,322
    Ifs your doing this...change out the PCV valve, and hoses.....i'll bet you money there dry rotted and pretty clogged up. Might want to consider changing the evap on there 2.....they get clogged up pretty also. All that shit goes right into the airbox...gets that all oily threw out the pipes, supercharger, intercool, and MAF. I've seen it to be the biggest dam problem in the world...so i just disconnected it from the airbox itself
