Helloy all,there was a problem doesn't hold (slips couplings), SACHS coupling, advise alternative which could digest more than a power
No problem! =)
I assume you mean the clutch does not hold the torque? If so then you might want to source an uprated pressure plate!.
Some clutch specialists may be able to offer to uprate your existing pressure plate, or replace with uprated unit.
SPEC clutches used to offer clutch upgrades for M111 also.
Hi,
Are you both running stock clutches and gearboxes?
I did run stock gearbox yes, I had some signs of wear on my drain plug magnet, you would possible want to run slightly heavier oil and hope it does not effect shifting too much.
Thanks for the photos, looks like neat install.
JJJ.
All kind time of day, it was succeeded to adjust on pressure 21psi, but corners of an advancing of ignition bad (there is a detonation) as extent of compression 8.8 it is a lot of, for normal control it is necessary to unclench the engine to 7-7.5, then it will be possible to adjust on more evil corners, and respectively to avoid a detonation. To put thick laying not to turn out as distance between cylinders very little, laying will simply blow, means only to do the piston under the order under smaller degree, or may be it is possible to pick up from something who possesses such information write please here the link to the sizes (parameters) of the native piston:
http://catalog.mahle-aftermarket.com...ilterId=965942
Are you using a dual mass flywheel?
Hi Paul,
You have used Siemens 550cc injectors. Do you happen to have the injector/model numbers?
Hello Krum,
Yes still have the injectors lying around, think I have them listed on a local auction site for $100nzd
I can try get the part numbers for you, if I recall you will need to pop out your fuel rail upright and cut off a few mm's then reinstall as they are shorter than stock..but dont quote me on that one it was a long time ago .
Thanks Paul!
