will this also work on a w124? my camber is totally out of sync and I'm tired of always buying tires!
I bought the MB Arts camber arms for my C43.
After I had them installed and realigned my car by my mechanic who was trained by MB, actually he was their best mechanic and ...............
When I drive my car at high speeds, it feels like my rearend is moving a bit sideways, I would say it feels a bit unstable!
I only had the camber arms fitted nothing else on rear axle.
I asked seller/owner of MB Arts camber arms, he says I also should get his adjustable Toe in arms to cure the instability???
Another cheap $310 dollars waysted if I have to buy them too!
Dude told me my new camber arms don't cope with my old factory rubber bushings, mixing new and old stuff is a bad combo according to him.
I haven't noticed any strange tirewear yet.
What's the best thing to do?
Removing camber arms or installing adjustable toe in arms?
I don't feel any instability @ normal speed only at 3 digit speed from 95 - 100 m/hr and onwards I notice the problems.
I also have 4 new tires Continental sportcontacts
Thanx
I have a 2002 CLK 320, would those part # work for my car?
Ok so since hea not making these anymore. Anyone know where i can get some at a decent price? Or piece together my own?
"anyone can drive a new car, it takes a true enthusiast to breath life into an older one"
Has anyone tried 8" one? I have the 9" sleeve and have it at the shortest length on both sides and the driver side is more positive camber than the passenger side. I would like to have the driver side a little more negative, only way I think is to shorten the sleeve.. 8" is way short in terms of camber..
1997 C280 Sport
Anyone want to chime in on how their car has been after installing these? Any failures? Anybody tracked or autoxd with these installed?
I installed these on my 99 c230k a few months ago. They started to squeak really bad. I tookhem off and put some sillicone paste on the bushings and reinstalled. No squeaks since and no signs of wear.
Can some one post feed back on how this are holding up, my rear left camber is at -2.6 right now and rear right at -2.5.
My car is running about a year strong after installing DIY camber arms. When I asked the shop I went to for an alignment, they said they were able to get the rear within spec, taking into account that the car was lowered. I ran them through an Illinois winter and they're holding up the same as when I installed them. No squeaks or anything.
thanks for the feed back MikeD. Did you install this exact ones or something else?
Has anyone done this on a non-lowered W202?
I just want to know if the aluminum sleeves are strong enough for every day use.
there is no reason you couldn't, but unless for some reason your camber is out there is no point
I thing is srt because if you look at the Current Charge Summary picture on the first page it says style STR
After attempting to install, both ends should indeed be straight. hopefully 202Brabus will edit his op so other people won't spend time and money getting the wrong ones!
here's a little preview of the camber links I am building. I am still waiting for delivery of my step spacer inserts for the shown right hand rod ends, and the left hand rod ends are also not here yet. they are extremely heavy duty QA1 HML10-12ht unts and I am sleeving them from 5/8" bore down to 1/2" bore and then using the Mezeire taper mount washers flanking both sides of the install against the upright.
It does not get any more heavy duty then this. these are pretty cuh an all out racing application that will in fact last a long time hitting potholes and such also. The rod ends shown are 55,692 lbs load rated and are HMR-12HT's from QA1
I put a US currency bill next to them for size reference.
Attachment 1467
