Hi everyone! i have a c200 kompresor w202 i realy like the c43 or c36 amg sound... so i want to put all the exhaust system of any of this 2 .. can i? what sound will i take? what u think pls help
it will sound nothing like a c36 nor a c43 period.
hmmm so any sugestion about any exhaust?/ i realy likeamg style can u sugest me any upgrade pls? THNx
Why did you post this question in 3 different places? Performance Tuning section is the correct place to post this question.
Delete the other 2.
Andy, as you are new here, I'll cut you some slack. Please refrain from posting the same question (or variation of it) in multiple Forums. Choose the Forum most appropriate to your question and post it there.
hmmm ok thnx for advice... but can u answer me plis to my question? i realy apriciate it !
Try doing a high flow cat upgrade and remove the central resonator. That should improve breathing and give some more sound. You will never get the sound of a c36 or c43. You don't have enough cylinders
You could drop in a C36 or C43 engine if you can get one, if you really want the sound, or cheaper to buy a c36 or c43
Not really. its much harder to swap in a motor that wasn't mean to be there, but for the M113 or M104 everything you need can be bought online through parts sites. Get a hold of a Mercedes shop manual and it will tell you how to pull and install the motor too.
The big things you need are the engine and transmission mounts. Aside from that its just wiring which if you have the ecu and harness is plug and play, if not spend the extra 2 grand to install a stand alone haltech unit which will probably net you 20 extra HP anyways. have an exhaust shop make a new exhaust and you are good to go. The cost is worse than the work swapping it in. 5.5L AMG long blocks are on ebay for 2k right now, you need the accessories, I was looking up part numbers and the A/C compressor is the same on the M111 and M113 so some accessories may carry over, and the transmission as well, but if you have a hoist and a shop manual and are mechanically competent you can do it in a garage on your own.
EDIT:
just to illustrate this
http://www.ebay.com/itm/Mercedes-Ben...#ht_500wt_1157
Motor, $1600 plus shipping <<<< yeah $1600 can you believe honda 4 banger cost more?!?
http://www.ebay.com/itm/TRANSMISSION...ht_1912wt_1399
tranny, $650 plus shipping
http://www.everythingbenz.com/z/part...0-430-55-parts
here is a list with part numbers to everything you will need. I would wait for the motor to arrive before I ordered things. Often even though they say there is no Throttle body, its included for example.
Completely mad.
Basically a 4 cylinder won't sound like a 6 or 8 cylinder because of physics and the number of exhaust pulses per revolution
1994 C280
1996 C36
2005 C55
2013 Volvo XC60 R-Design
1999 Porsche 911
thank you all for good advices !
i have c200 kompresor not c280 :-/ ...
In my case the C280 has the M104 motor or inline 6 just like the C36. I chalk it up to the displacement.
1994 C280
1996 C36
2005 C55
1999 Porsche 911
>>99 S202 RED 250TD Daily.
>>89 2.6 RED w/16vkit. POS
can anyone sugest any other exhaust ? i mean any model beside amg.. ?
I've heard good things about Supersprint.
andy, type w202 in youtube and there should be a few videos of exhaust swaps and the sound after. Just click on one and the chain begins
Also, the sound should be nearly the same along all the w202's that have a I4 engine
thanks i gonna try now
the M104 sounds beast without any exhaust =D
you got a 4 cylinder W202 right ? Do a resonator delete and add a magnaflow 14815 double wall dual tip universal muffler
Its what OCklasse has as his exhaust setup and ive heard it in person numerous times sounds great.
heres a youtube clip
hmm many thanks..but can u explain me pls what is a resonator delete and how to perform it? thnx
