Results 51 to 75 of 97
Thread: best bang for buck
  1. #51
    If the second hand engine has good compression I would leave it in the state you purchase it,opening it up is wasted money,If by some reason you damage it while tuning then rebuild.=) Like most transmissions,if nobody changes the oil/filter they fail,fix it only if it fails and dont worry about it until then.
    I know very little about the coswoth engine,but im pretty sure they ran solid lifters and different valve spring type,you cant directly compare this to the M111 head with hydrolic lifters,the wiegh more for a start.
    Cam design is really speciallised,engine builders normally dont have the software or equipment to sort these issues,locally we have companies like this: http://http://www.kelford.co.nz/ If you can,try get away with using stock cams but remove some of the overlap buy adjusting timing,it may depend on how much piston-valve clearance you have,if you cant get away with it this way you may have to adjust duration etc which is custom cam design.
    The best thing you could do would be to speak with someone who has turbocharged a non-turbo engine many times(not an ECU tuner),have the M111 engine degree'd and descuss what possible changes you might want to make before you start the project.
    5k is not alot for a completely custom turbo project,but im sure there is a long line of people who will tell you it can be done for next to nothing!.=)
  2. #52
    Just found this,some of the points sum up what im trying to describe to you:
    http://http://www.capella.co.nz/site...ord.co.nz/faq/
  3. #53
    Jun 2011
    726
    Well my tuner also is an engine builder, he does both. It's sounding like messing with the cams is more trouble than it's worth. If there were cams already made that i could drop in like some engines then great, but again like everything else with these engines it's 100% custom.
    Any opinion on this manifold?
    http://www.vulcanturbo.com/Mercedesbenzmanifolds.html
    It's the only one you can buy, otherwise I'll just have one made.
    Completely mad.
  4. #54
    there are pre-made cams, they are very hard to get... i have a set, made by schrick
    Also, you do not need a custom intake manifold done
  5. #55
    Jun 2011
    726
    Thats a turbo header.
    Completely mad.
  6. #56
    Wheres the face palm icon when you need it. I give up^^.
  7. #57
    Jun 2011
    726
    lol j/k
    I don't think I will be doing a custom intake. It's not necessary. Although I may down the road (I intend to keep the 202 for awhile). I don't think it will be necessary to reach my goal of getting C43 parity. Do you know if a bigger front mount will fit in the stock bumper? or will I have to stick with the stock front mount until I get the Rieger kit down the road?
    Completely mad.
  8. #58
    I can't vouch for the 202 front bumber... but my front bumber can fit a huuuge front mount, minor mods only!
  9. #59
    Jun 2011
    726
    Well Andrew is a great fabricator, I'll see what he can figure out.
    Completely mad.
  10. #60
    If its anything like the r170 one, I had to remove some plastic airdam type stuff and make a custom bracket
  11. #61
    Jun 2011
    726
    If it's a case of removing non structural plastic then no big deal.
    Completely mad.
  12. #62
    Found it!....
    At the end of the day Its upto you to decide what to do with the cam setup,though I just cant help but be feel compelled to make you understand the reasons why you should investigate it at the begining - even if you do not change it.
    If you want to put it behind the bumper your pretty limited with IC space on the 202 ,unless you cut out metal or remove the a/c fans. you could go with a much thicker IC to compensate for hieght and mount under the impact bar like i have,but you might want to change the front bumper to suit.
  13. #63
    Gaks,
    Have you got a dyno plot for the R170?
    Your right,you dont need a custom intake plenum,however its difficult to enlargen the opening under the stock DBW should you decide to. I couldnt help but notice the dyno plots on the race car you compare to are alot different to mine,it could be the graph but torque appears to be very peaky,with power and torque dropping off fairly early in the rpm,i wonder if this is a turbo flow issue,or intake system restriction?..i would doubt its any restriction pre-compressor or after turbine.
  14. #64
    My dyno was when I had problems that I'm still working on fixing. It is very "bumpy" indicating a fuel issue.. but otherwise it was about 187rwhp/190 somethin rwtq, the dyno was underrated also by 20-30hp from what the guy said.
    Its very possible the OEM intake mani will affect the hp/tq curves, as that is how a lot of people will adjust those curves... making longer runners, different size plenum, etc. As far as Cams go, he can try to find a set of the schrick ones, otherwise they are gonna be expensive
  15. #65
    From what I was told, this is the new settings on the Cams I have... there is supposedly a second variation with different specs:
    Schrick camshafts:
    ref.no.: 0285 E1 521-00 (intake)
    opening duration:252°
    peak angle: 96-116°
    lift max.:10,3mm
    lift at TDC: 0,3-2,5mm
    ref.no.: 0285 A1 521-00 (exhaust)
    opening duration: 252°
    peak angle: 108°
    lift max.: 10,0mm
    lift at TDC: 1,1mm
  16. #66
    Jun 2011
    726
    how hard is it to get these cams?
    Completely mad.
  17. #67
    i waited about 2 years for 1 set to come up for sale.. So it can be tough, you may be able to contact schrick and see if they have any left over
  18. #68
    Jun 2011
    726
    Since we have the specs of the shrick cams, do you think i could have the stock cams reground to spec?
    Completely mad.
  19. #69
    Are these shrick cams for the SC setup?
  20. #70
    Honestly,do yourself a favour - google,research,inquire at cam manufacturers...do everything possible to understand the differences in timing/duration/lift between a turbo cam,NA cam and super charger cam setup,especially one with internal recirculation and large overlap...you will find reversion is your enemey and will effect you in a very negative way...*edit - this is why i no longer have a turbo m111.
  21. #71
    Feb 2007
    187
    What level of boost were you running when you did have the turbo?
  22. #72
    Yup, I am probably not installin these cams on the engine I will turbo.. but on the engine I will have that stays s/c
  23. #73
    Quote Originally Posted by NW_Merc View Post
    Around 15-16psi,so yes the cam timing becomes more important the more pressure you run. On the most recent setup I ran a T3 .82 housing(previously T25 .63 then .82 then T3 .63) with a Garrett 60 series hot side,Running the larger housing with reduced backpressure helped tuning alot and not just in top end,although we didnt realise this at the time dropping the backpressure also had a positive effect on how much usable fuel we had,ie it wasnt being spat back out the intake and pooling in the runners,then being sucked back in only to pool around the rings and end up in the oil...aka bore wash.
    I degree'd the M111 when i last removed it,there is a lot of overlap.
  24. #74
    Jun 2011
    726
    I understand the difference between a turbo cam and an NA cam. Turbo cams have very little overlap and NA cams have a lot. I do not know what an sc cam is like.
    Completely mad.
  25. #75
    Goodluck with the project.
