Results 1 to 6 of 6
Thread: What is the part number for the reading light?
    Mar 2011
    162
    In the front dome lamp on the top right hand corner there is a little square light. When i took out the socket i think that's what it's called and removed the bulb i broke that part. What is the part number for that and also what is it called? I am planning to go to Beshoff Motorcars within the next couple weeks.
    Mar 2011
    242
    That isn't sold separately. Its sold as a unit only. Best bet is to locate another unit. The two larger lenses are available but not the square reading lamp.
    **item 35 is a plug cover for the sunroof switch**
    **item 25 is the reading lamp bulb holder**
    **item 20 is the reading lamp bulb**
    Mar 2011
    162
    damn i really didn't realize that they didn't sell it separately... i thought they would since it's a relatively easy part to take in and out...
    Jul 2011
    UK
    249
    the reading light is a simple t10 501 bulb. atleast i know mine is, as ive just bought some to replace mine! I'll take a picture of mine for you tonight.
    Mar 2011
    162
    it's not the bulb i needed... it was the socket and I already got the part... now it's just a matter of whether the led bulb i order will fit in the little space i have...
    Mar 2011
    162
    i will post the part number once I get home as right now I'm not at home...
    P.S. It will only work with some w202s so I take no responsibility if the part number I provide is incorrect.
Tags for this Thread
