It'll depend on the tire profile. 255 seems to be pushing it as I'm about to run 255/35, so pretty low profile and that's on a 9.5" wide wheel. 225/40 isn't unsafe and does not cause bad tire wear if that is your concern. It actually falls within a lot of tire manufacturer's recommended setups.
My main thing is id like to have the wide look more then anything. What tire setup you think I should run? Since all my wheels will be 8.5s I think tjeir the SLR knockoffs. ...if that helps
Just waiting on spacers, extended lugs, and some warmer weather at this point. I found a guy locally that is selling a set of w202 Eibach springs with cups for $150, used only for a few months on his C43. Can anyone chime in if it's worth getting them for this price?
do we have some decent width rims available that will fit with out spacers??
