Heat shield is a must. Your sucking in hot air. You could try fabbing one up from sheet metal. It isnt hard to do.
I got my KN air filter intake and i was wondering if i can get a head sheild anywhere or make a custom one, OR is it fine the way it is?
any advice would be appreciated thanks!
btw its a 98 classic c230
My W202 2000 C230 Kompressor
Like us on Facebook!
hmm Would i have to get it custom made or is there online places i can order to get this resolved?
i had mine run like that in my c280 for a few months and it was worse then stock. best bet is to definetly get a heat shield and run a longer intake tube so its farther away from the exhaust manifold
Hmm thing is i ran into a problem and i do have a longer tube but , the sensor connector does not fit through the tube so i had to use it like that. So it will get worse as so on? Any ideas on how to create a heat shield around it?
http://cgi.ebay.com/ebaymotors/3-CON...Q5fAccessories
Would that make a difference?
Yeah, try to get it a bit longer if possible. You can build yourself a heat shield, its not hard, you just have to force yourself to do it. Open your engine bay, buy some sheet metal, and sheet metal cutters, and start measuring and imagining where you want the heat shield.
Here is my setup.
All it is, is cutting and keeping in mind your want to seperate the heated parts from the intake. Hope this helps.
Also, be sure to buy thin sheet metal, you could buy thick sheet metal, its just manipulating it that will make for some extra work.
LOL worth a try, I do have a longer tube but my sensor that connects it wont fit through the tube and i will just have a hole in extension tube for my intake any suggestions?
You could try to buy a couplar (The blue thing)... Idk if that will work. I will take a look at a C280 in the morning (luckily my brother owns one) and see what can be done.
http://www.autopartsway.ca/PartDetai.../pagenum1/tabS
Thats exactly what i have i need to connect my air sensor to that middle hole. also thing is i dont think it will fit. And its like a weird tool to take off. I dont have a screwdriver that has 5 star with a dot in the middle ?
yeah, the black thing that connects is a couplar. Sucks that it has the throttle hole, idk why they designed that for your car with no throttle like mines. You could just put tape over that damn thing if cosmetics doesnt mean much to you. Find the tool, better to use the whole thing than just the filter, or else it was a waste of money, use the whole piece, figure out a way to close up that whole. and than work on the heat shield. In that order
yujin i like your idea of the covering on the overflow hose coming off the coolant resovoir kkinda off topic though but thats a secure torx bolt the 5 star with a dot you can only get those as bits for say a nut driver or drill your best bet is to try your local hardware store for that tool
haha yea i have a few different sizes of wire braid hose at my job for truck air brakes i might get some to cover that line try and keep as much heat away from that filter as possible haha
Couldnt hurt, your in Taxachussettes?
In Winter time, my intakes should reap the benefits of really friggin cold air lol.
born and raised lol with my intake i had, my car ran 100 times better this winter so the colds a must haha
I cant wait, I hate this rainny and muggy BS we been getting, been killing my car :/...
same here but i just can't wait for the snow thats when the real fun starts haha
Mmm real wheel drive on slopes and going down hills, and all that drifting fun in the parking lots. Oh baby!
Only set backs are the salty roads.
You have pics of your car up here on Club202? You plan to add a Decal?
not yet haven't had time but its black with gray interior needs some body work though its gotten a beating from driving back and forth to work
So i shouldnt leave it like this, or else i decrease hp as time goes by right? i need to extend it as far as possible right ?
kk thanks for all your help guys!
Check out this Member's site and see if it can apply to you: http://www.2phast.com/C36/c36.htm
