First, if you remove it, you WILL have ugly holes there...unless you are replacing it with something else. It's not glued on like the other badges
If you still want to remove it, you pull out the clips which holds the trunk lining in place, then you will see there are two grommets which hold the pins of the star. You pull those off with pliers and the star is removed.
