Gauges
I'm trying to decide where to tap into for an oil pressure gauge as well as a boost gauge.. Any suggestions would be great!
for the boost gauge any vacuum line after the throttle well do the easiest one is from fuel pressure regulator , as for the oil pressure gauge if you are using manual one you could run a line from where the oil sensor (it's on the left side of m111 under the exhaust manifold) to your gauge
Thanks man! That helps me out a lot
