pm sent
I need to have new suspension bushings put in and I figured I might as well get some performance bushings. Does anyone know of a place I can get them?
Completely mad.
do you need front lca innerbushings?
a few years ago there was a poly bushing sold on ebay replacing headbushing which goes bad being non solid rubber
i have a set of 2x new polybushing i never used on my car.
sorry dubble post
kowalski you willing to let them go since you never used them? shoot me a PM or something
"anyone can drive a new car, it takes a true enthusiast to breath life into an older one"
Both speed nuts and barrel clips are available with built in seals to ensure that moisture does not pass through the stud hole. These bushing are quite useful for control movement and maintain alignment in sway bars, control arms, and other stressed suspension components without the harshness or resonance.
