i bought my hids from theretrofitsource.com definately more expensive than the cheap kits. I bought the 4300k 35watt kit. The bulbs fit in fine, just the backs are a little too long for the housing. So i modified the foglamp bulb cover a bit so it would fit. I then covered the lens with the yellow laminx, as i like the yellow light. The foglights are easily twice as bright and go a great distance down the road.
The laminex is worth the $20 bucks. Not sure if im a fan of the yellow yet, but it comes in clear and smoked as well. it hides the pitting quite well and goes on easily.
hid kit. http://www.theretrofitsource.com/pro...oducts_id=3958
I ordered the kit with can-bus wiring harness. it is two individual harnesses instead of the normal one the kit comes with. do some research on the website and it will give you a better explanation.
I mounted the ballast's to the body above the lamps, there was an unused bolt on each side.
