Results 1 to 9 of 9
Thread: Suede Headliner
    Mar 2013
    7
    Suede Headliner
    so i started the suede headliner i finally finished all the trimming and cutting and glueing of all of the parts but it was a pita to get all the old foam off the headliner.
    I was trying to vacuum all the loose foam with my shop vac
    steel brush helped alot but there were alot of stubborn areas.
    here it is with most of it off
    but it came out pretty good ill post pics of it installed tomorrow.
    also Japanese plastic > German plastic, just about every damn plastic trim on this car that i touch just falls apart i just completely covered the sunroof shade ill cut the holes out later when i can afford $120 for a handle and 2 vents..
    I did do all A ,B and C pillars but i only took a pic of the A pillar and they came out pretty good too.
    got it all installed today, its not all perfect but its not bad for my first time working with upholstery.
    then i decided to remove the old rotten leather from the steering wheel til i can afford the wood and leather one from an E class.
    heres the back all done
    let me know what you guys think
    Senior Member jc1kz's Avatar
    Aug 2012
    TX
    225
    looks great...how long did it take you from start to finish?
    Mar 2013
    7
    about 2 days but only cause cleaning the old foam off was such a pain in the butt and after i had everything glued i waited till the next day to install everything because i wanted to make sure the adheasive was properly cured before i installed it.
    btw the MBUSA Star Service CD says you should remove the passengers door to remove the headliner but a much easier way is to remove the passenger seat and center console and the headliner will come out the passenger door just remember to lay the driver seat back as far as it will go
    Great work
    Senior Member vixen_w202's Avatar
    Nov 2012
    Lancaster, CA
    418
    I don't mean to hijack the topic, but it's mostly related to what's going on here:
    Does anyone know where you could get some headliner fabric made custom with your own logos?? I hate the sellout Louis Vuitton headliners I see and besides that's not my thing.....but I would die for a black suede or luxury headliner that has the Famous Stars & Straps or Volcom logos stiched in the fabric because those are the two clothing brands I am in love with and basically all I wear...heh. It'd be cool if I could start personalizing the interior in that sense.
    Something like this:
    or this:
    If anyone could point me to where something like this could be possibly done, I'd appreciate it. I would have done it already as my headliner is sagging pretty bad, but I just dunno where to go to.
    Apr 2011
    Antarctica
    551
    Quote Originally Posted by vixen_w202 View Post
    or this:
    You want the inside of your car to look like a pair of pajamas? lol
    Great suede wrap! I've been wanting to do this for so long but I'm afraid of messing it up! I may have to give it a go this summer...
    Put whatever you want on the headliner. Personally I don't care for promoting brands without getting paid.
    Merc headliner was 1/8 thickness from the factory. Many people take the cheap way out and get the stuff from Pep Boys that is 1/4 thick.
    This will mess things up especially around the lights. When the fabric is too thick the clips won't seat in place. Also the sunroof cover won't won't slide back easily.
    I am currently going thru this right now. The headliner I got from the donor car was covered in 1/4 inch. I had to pull back fabric edges and remove the foam. Sliding the sunroof cover is a 2 hand operation.
    Get what you want. Just make sure its the right thickness.
    Mar 2013
    7
    the one i used was 1/8th thick and the sliding sunroof cover was a bit tight the first day but now that its been sitting it slides smoothly now
    Mar 2013
    7
    double post
