its a bit crude i know but once i get some testing done i will decide whether the blower is staying or not, blower could be made fit if i machined a new front shaft and housing but i will see what happens.
blower is going to force feed the turbo on low boost only, then the turbo will take over from 1.2 to 2.8 bar(estimated)
Sounds promising from the little that I'd know about your set up and possibly the wisest thing is you being flexible about the end result. How will you control the S/c boost pressure to the turbo, simple BOV?
i was thinking of making a flap that simply sucks open when the turbo creates negative pressure. something like this maybe;
