Definately a must for any car older than 5 years. Teflon braided lines will in fact make a major improvement in initial braking response and pedal sweet spot.
So finally had my ss lines installed. What a difference this upgrade makes! Brake pedal is solid not mushy and, in combination with new rotors and pads, stops on a dime.
I highly recommend this upgrade. It is quite affordable, and immediate impact on the overall braking system. IIRC, my Goodrich lines were about $100.
Good to hear because I'm not too happy with my cars brake feel, excessive pedal travel and non inspiring brakes generally. I must look into doing the hoses etc.
JJJ.
Hi, can you put a link for this item, please or part number at least. This is a great stuff in my opinion. Can not find the correct item, which will fit without modifications. Thanks
GS34030 bought from hrpworld.com
I used a set of goodridge braided brake lines.. really good product. they make a huge difference even with stock brakes.
