Results 26 to 50 of 54
Thread: W202 2.0k upgrade
    May 2013
    Bulgaria
    203
    May 2013
    Bulgaria
    203
    May 2013
    Durban South Africa
    264
    Now if we only understood the content
    Are you still running the smt 6 K-B
  4. #29
    May 2013
    Bulgaria
    203
    This my friend is a link to download ECM + the password to extract the compressed file where ECM is.
    Yes but at this stage I don't need it. Especially since I have found ways and means to flash the ECU.
  5. #30
    May 2013
    Durban South Africa
    264
    Quote Originally Posted by KrumB View Post
    Hi Krum.
    You got any dyno figures on the re flashed ecu?
  6. #31
    May 2013
    Bulgaria
    203
    Quote Originally Posted by Abbaso View Post
    Hi Krum.
    It's the first post.
  7. #32
    May 2013
    Bulgaria
    203
    Hi Krum.
  8. #33
    Senior Member dokotela's Avatar
    Oct 2007
    Durban, South Africa
    366
    needs password
    W203: 02 C32 AMG
  9. #34
    May 2013
    Bulgaria
    203
    Password: auto-bk.ru
  10. #35
    May 2013
    Bulgaria
    203
    I did a 1/4 mile test run and here's the result:
  11. #36
    May 2013
    Bulgaria
    203
    After some tuning here's the result:
  12. #37
    May 2013
    Durban South Africa
    264
    Excellent results there Krum!!
    How was it tuned? Via OBD,38 pin or soldered chip? Are you still having the s/c switch off problem? Which 2 wires did you clamp with the diode?
    Sorry for all the questions
  13. #38
    May 2013
    Bulgaria
    203
    Hi,
    Its tuned via Galletto 1260 (38-pin cable).
    I found what's wrong. The throttle cable had to be adjusted.
    I'm using a SMT 6 piggyback and it restricts the signal.
  14. #39
    Apr 2013
    Ireland
    829
    That's a great result Krum and even better that is from 200K. Are you happy with those stats or were you expecting more? Have you sorted the issue with the S/c disengaging at sudden WOT?
    JJJ.
  15. #40
    May 2013
    Bulgaria
    203
    Hi J,
    Everything sorted out. Quite happy with the result!
    Looking for more thaw.
  16. #41
    Apr 2013
    Ireland
    829
    Hi Krum ,plenty of snow there now I'd imagine. Did the MAF clamp sort it?
    JJJ.
  17. #42
    May 2013
    Bulgaria
    203
    We have no snow for now.
    The problem was with the throttle wire. It was not adjusted. The previous owner tightened it too much.
  18. #43
    Apr 2013
    Ireland
    829
    Good to know , must check mine as I did adjust up the cable some time back.
    JJJ.
  19. #44
    May 2013
    Bulgaria
    203
    When throttle pedal pushed all the way down (WOT) the throttle solenoid lever should not touch the plastic limiter (there must be about 1 mm gap).
  20. #45
    Apr 2013
    Ireland
    829
    Thanks Krum. I presume you have a cable from the throttle pedal to the throttle switch/solenoid/potentiometer mounted in the engine bay (which in turn is wired to the electronic throttle body)?
    http://www.auto-parts.spb.ru/cat/cat...4b7e5153582d03
    JJJ.
  21. #46
    May 2013
    Bulgaria
    203
    That is correct.
  22. #47
    Apr 2013
    Ireland
    829
    Cheers.
    JJJ.
  23. #48
    Sep 2014
    Czech republic
    9
    how you achieved such amazing result? Pulley and?
    I also plan to tune your c200k
    thank you for answer
  24. #49
    May 2013
    Bulgaria
    203
    Hi,
    I used 220 mm crank pulley and 87 mm kompressor pulley. Also bigger intercooler, colder plugs and ECU remap.
  25. #50
    Aug 2014
    8
    Hello! Can you give us a link where we can get the pulleys from? Thanks!
