Results 26 to 50 of 78
Thread: E55 18" monoblocks wont fit
    Senior Member Christopher's Avatar
    Apr 2012
    SoCal
    577
    2 inch bolt with h&r spacer and brabus rim
    the amount of room untill thread starts
    caliper
    bolt
    dont even know what size spacer this is but its the one i used on the rear with the brabus rim
    amount of room left with e55 monoblock and spacer
    99 Porsche Boxster (sold)
    00 Chevy silverado(traded)
    02 bmw 330CiSold)
    94 MB c220(deceased)
    73 Porsche 911(deceased)
    96 MB 280 Sport (traded)
    96' c36 AMG (current Ride)
    97' c280 Brabus (new daily driver)
    97' Range Rover 4.0 (for sale)
    01" Jaguar Type S (for sale)
    Apr 2012
    SoCal
    577
    is it ball or cone that these rims need for the lug bolts?
    02 bmw 330CiSold)
    Jan 2004
    San Francisco
    786
    Just out of curiosity what is the measurements and ET of the rims? The W210 E55 wheels are 8x18 with ET31 and 9x18 with ET35. I'm almost thinking you have rims from a S-Class as a spacer that thick would never come close to working with the E55 Mono II's I have.
    1994 C280
    1996 C36
    2005 C55
    2013 Volvo XC60 R-Design
    1999 Porsche 911
  4. #29
    Apr 2012
    SoCal
    577
    Was hoping someone here could just eye ball them and tell me the exact specs of these rims I didn't see the stamp anywhere on the rims with the specs but maybe there just too dirty from the inside. Anyways very frusterating hopefully gets resolved soon
  5. #30
    Apr 2012
    SoCal
    577
    Hwa 140 401 0102
  6. #31
    Apr 2012
    SoCal
    577
    Quote Originally Posted by mbsickness View Post
    your right w140 S class... What now?
  7. #32
    Jan 2004
    San Francisco
    786
    Well that actually explains a lot. So are the rims staggered or are all four the same dimensions? The next item is if you are going to try and use the 245/275 setup assuming they can even fit inside the wheel wells. At this point I would say you need spacers all the way around.
    1994 C280
    1996 C36
    2005 C55
    1999 Porsche 911
  8. #33
    Apr 2012
    SoCal
    577
    Not really sure what staggered means but the rims on the back look wider than the ones in the front of that answers your question. I wish I knew what the size of these rims though
  9. #34
    Jan 2004
    San Francisco
    786
    So staggered means the front and rear rims are different widths. The size of the rims is stamped on the backside just where you found the part number and offset and will look like this
    In the above case the rim 9 x 18 with an offset or ET35.
    1994 C280
    1996 C36
    2005 C55
    1999 Porsche 911
  10. #35
    Fremont, CA
    1,900
    you need longer studs definitely... no stamping on the back of the wheels? take pics and post...
  11. #36
    Fremont, CA
    1,900
    Quote Originally Posted by Christopher View Post
    Hwa 140 401 0102
    came from 140 s class and not e55... maybe needing at least 15mm spacers and your bolts look 50mm shank... you may need 60 or 65mm shank..
  12. #37
    Apr 2012
    SoCal
    577
  13. #38
    Apr 2012
    SoCal
    577
    make sure the center bore of the spacers is 66.56 or a tad bigger.... not too big or too small or its just a waste of money
    I'm here in chatworth picking these up I hope it's not a waste a money even though I know the bore is different. Not sure if I could make this work but don't really see many options. All I know is that one thong is for sure and it's that these lug boltsvare longer than the ones I have nd there the ball lug bolts that the rims take that alone is worth a lot I'm basically going to get everything for the price of the bolts not to mention that they are very hard to find, and if I do find them they will be pricey. This guy should be here in a couple minutes I'm sitting in my car thinking about what to do. Any remarks?
  14. #39
    Apr 2012
    SoCal
    577
    So this is what I'm getting plus 10 more long ball lug bolts
  15. #40
    Jan 2004
    San Francisco
    786
    Wow I have never seen a wheel with no dimensions cast into it...I guess there is always a first time. Right now I assume all for rims have the same part number and therefore are the same size and offset. According to the part number you have a 8.5X18 rim with an offset or ET of 47. This is what I got out of a an online offset calculator. Based on how tight my car runs with 255/35 tires in the rear if you were to go with the 255/35 rear you would need something like an 18mm spacer. For the front using a 225/40 tire you would need something like a 9mm spacer.
    1994 C280
    1996 C36
    2005 C55
    1999 Porsche 911
  16. #41
    Apr 2012
    SoCal
    577
    this was the guys benz that sold me the adapters and spacers he has a bunch of cool cars he also has a really nice cosworth 190.
    he said i was gambling by buying the adapters but all i really cared about was the long lug bolts. still came out pretty expensive though not to mention i had to drive an hour there and an hour back
    02 bmw 330CiSold)
  17. #42
    Jan 2004
    San Francisco
    786
    Hope it all works out. Those look like 19's on the sellers C36. The creeping costs remind me of my C36 body kit....having known how much it would cost in the end would have prevented me from starting the project but once you start the project you are committed to seeing it through.
    1994 C280
    1996 C36
    2005 C55
    1999 Porsche 911
  18. #43
    Apr 2012
    SoCal
    577
    Ready or not here comes the BOOM
  19. #44
    Jan 2004
    San Francisco
    786
    Congrats on getting it all fitted. any rubbing or clearance issues? I assume you are still running the 275/245 combo.
    1994 C280
    1996 C36
    2005 C55
    1999 Porsche 911
  20. #45
    Apr 2012
    SoCal
    577
    Nope... Just kidding heck yes there is rubbing and every little dip the back hits hard, looks like I'm gonna have to go 225 in the back and 205 in the front
  21. #46
    Apr 2012
    SoCal
    577
    I really want adjustable coil overs now, or maybe just maybe air bags just because SD202 makes it look so cool
  22. #47
    Apr 2012
    SoCal
    577
  23. #48
    Fremont, CA
    1,900
    you should be good with 225 all around or 215 fronts 225 rears
  24. #49
    988
    yup exactly! 225 all around. I run 225/35 in the rear with 25mm spacer. no rub at all. even when aired out.
  25. #50
    Member
    May 2011
    Dallas
    84
    i have 245 35 20 on the back no rub. im on eibachs aswell stock pads. you see all the spots on the inside of your wheel well that are rubbing? Hit those with a hammer. The grey plastic moulding near the rear wheel must also be shaved and rolled. As for the front youll have to remove the fender liner and roll the fronts and remove the little vent shaped piece that comes off the front bumper. Zero rub on 10xdub.
