Zayed,
You have fitted CLK55 mufflers before?
Yes the rear muffler top hanger needs "tweak" maybe 10mm to make it sit perfect, did you also modify the rubber hanger?
That makes sense, EPC show the CLK55 radiator fitted(updated) to C43 but does not show cooler lines to use the internal cooler. The CLK55 one is in a new condition, I will use this but retain the original C43 trans cooler.
Regards,
