Hey Dennis,
I'm looking forward to the challenge!, I have always wanted the newer ICM and 5.4 engine, the plan is to make a factory look install out of it.
Yes sure thing, plenty of pics to come
Remo,
Pretty sure all C43's are 3.07? ( 202 housing - 185mm crown)
Yes exactly the reason I want the CLK55 ECM,I'm sure it will be same as C55 tuning seeing as they use possibly the same exhaust,the CLK55 front portion and cats are all 202 C43 parts,the rear muffler looks like a modified C43 one to suit the bumper(just cut and welded down the outer side).
I have read the C55 uses a different centre muffler, Ironically the CLK55 centre muffler is different part number(#208) to C43, It should fit the 202. I will compare them later this week.
I've had a look through the ME2.0 ECM on C43 and there is no option to code anything in developer, I think it maybe only possible on ME2.8?....
