Hey Dennis,
Yes plan is to run the clk55's A220 2.82 diff with matching axles,outer drive flanges and 4 finger prop shaft ..AFAIK same as the C55 has.
Zayed suggested keeping the C43 drive system,I think this is fine if you swap the engine only, however if I run the CLK55 ECM I dont think I can run the C43 TCM with tiptronic so need the CLK55 TCM which is set to 2.82 diff.
Another option he mentioned might work was to run the 808/809 E55 TCU with C43 ECM to get 2.82 ratio, however I think that would only be suitable for the C43 ECM.
Regards,
