Results 1 to 25 of 350
Thread: C43/CLK55 Conversion
Hybrid View
    3,219
    Clk55 17" Lite weight spare wheel fits over the stoptech brakes and is 5kg lighter than the C43 mono spare... win.
    The 208 or 210 cluster does not fit the 202 perfectly, even though the front-on cut out is the same, the housing are suited specifically to the surrounding dash shape. A quick fix for this is to take a 202 housing and marry it to the gauge part of the 210/208 cluster which is near identical to the 202,the trick is to make a jig to hold it and use a cut off wheel/mill for best control. finish off with super matte chalkboard paint and epoxy to mate it all up...Boom!
    The only give away is the lack of clock buttons on the right, I hope to make some tidy blank-off's for these.
ID:	1788Click image for larger version.
ID:	1789Click image for larger version.
ID:	1790Click image for larger version.
    >>99 S202 RED 250TD Daily.
    >>89 2.6 RED w/16vkit. POS
