Results 1 to 9 of 9
Thread: sunroof rubber seal
    Sep 2011
    MD USA
    178
    sunroof rubber seal
    Does anyone know the part number of the sunroof rubber seal. my sunroof leaks water on the upper right corner where the seal is cracked.
    Member
    Apr 2007
    Los Angeles
    61
    +1..
    Sep 2011
    MD USA
    178
    no body knows the number?
    Sep 2011
    MD USA
    178
    I finally found it with the help of member from benzworld. the number is 1247800298. he/she mentioned to not buy the Viaco becasue it doesn't fit correctly.
    Apr 2006
    Europe
    752
    old sunroof seal is it easy to remove and fit the new seal?
    any glue needed to make the new sit in place or is it only to press the seal around the edges?
    Sep 2011
    MD USA
    178
    I'm not sure haven't done the job yet
    Dec 2006
    Leesburg, FL
    219
    It just presses in. You could use a bit of water based lube if necessary.
    Apr 2006
    Europe
    752
    Quote Originally Posted by nhmercracer View Post
    does stealership provide any lube or glue kit when buying this seal?
    when the old seal is replaced and new seal is fitted does it sit properly not coming off?
    when sunroof is closed does sunroof press the seal into the slots around the sunroof?
    Dec 2006
    Leesburg, FL
    219
    It fits into a groove along the edge of the opening.
