NEW AND NEED HELP! Front Camber?!
Hi I'm new, I have a w202 and looking for a way to camber my front wheels without spending a load f money, the only thing I've found so far is some adjustable bushes from Kmac which come in at £260, is there a cheaper way if doing this? HELP! Many thanks in advance. Jim
Nope. no cheap solutions, sorry. Someone is working on an upper adjustable control arm but that will probably be just as costly and effects wheel offset choices. The only wat to prevent this is to keep the car static ride height above aprox 26.5" front fender lip height off the ground The arm geometry will parallel the ground more at lower heights and you loose factory adjustment range.
Tags for this Thread
